Very tight hinge while I open Zenbook Pro Duo OLED UX582h
kiuzodono
Is it normal, that I can`t open my new laptop with one hand? It`s very tight when I open it.
I saw videos on Youtube and it seems like easy opening with one hand there. What do I need to do?
thnx!
RAJU_MSC_MATHEM
Zen Master I
kiuzodono
thnx!
Take to the nearest Asus service center, the technician will make it a little loose of tight hinge
Falcon_ASUS
kiuzodono
thnx!
@kiuzodono
Like other user's reply, I would suggest you bring back your laptop to our service center.
http://www.asus.com/support/Service-Center-All-Countries/
Also you can contact the local service center for help. The following is the contact information:
http://www.asus.com/support/CallUs#
ASUS_Bot
Rising Star II
