04-19-2021
05:42 AM
- last edited on
01-16-2024
01:54 AM
by
ZenBot
04-19-2021 06:33 AM
dfwnorthwestGenerally No signal means , the connection between monitor to laptop is damaged or cable fault or HDMI port fault.
- System:: Windows 10 pro
- Battery or AC: Both
- Model: ZenBook UX534FTC_UX534FT
- Frequency of occurrence: all
- Reset OS:
- Monitor ASUS VA32AQ
Detailed description:
Display from HDMI port to external Asus monitor works fine.
However, when using an OKX USB hub, if I pull the HDMI cable out of the laptop and into the USB hub HDMI port, the screen reports "no signal" and then goes blank. What can I check?
USB-C display port wont display to external monitor but hdmi works from laptop
04-19-2021 06:47 PM
