touchpad disappeared from device manager PROBLEM reinstalling Driver
susa2022
System: Windows 10
Model: UX461F
Detailed description:
Trying to install Touchpad Driver through Asus Download page (wont let me post link)
Error Message from Powershell
.\Install_PTP.bat : The term '.\Install_PTP.bat' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try
again.
At line:1 char:2
+ .\Install_PTP.bat
   + CategoryInfo         : ObjectNotFound: (.\Install_PTP.bat:String) [], CommandNotFoundException
   + FullyQualifiedErrorId : CommandNotFoundException
Anyone successfully install this driver? How did you do it?
ANY HELP GREATLY APPRECIATED
Falcon_ASUS
susa2022
  1. System: Windows 10
  2. Model: UX461F
again.
At line:1 char:2
+ .\Install_PTP.bat
@susa2022
If you cannot find the touchpad in device manager, it may be caused by an error in the touchpad hardware. I would suggest you bring back your mobile to our service center.
http://www.asus.com/support/Service-Center-All-Countries/
Also you can contact the local service center for help. The following is the contact information:
http://www.asus.com/support/CallUs#
