Touch Pad problem on Zenbook
RajeevKalita
System:
Battery or AC:
Model:
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:Hi the right click button on my asus zenbook is not working, this happened after I had recently updated a windows 11 patch update. Can anyone assist
5 REPLIES 5
FongPoui
Rising Star II
@RajeevKalita
Hi, we cannot continue from your post because we don't know what zenbook model you are using...
FongPoui
Rising Star II
@RajeevKalita
But you can try easily by press Windows sign for opening the system then click on Bluetooth & Devices (Touchpad is considered as a device). Click on Touchpad and you will see if your touchpad status is on or off. During your upgrade to 22H2, windows could disable some devices.
ZT-c07932e9
Hi , i have the Zenbook Pro 15 UX580 After 22H2 update ,
TouchPad Works but only the Cursor.. i cannot Right Click ,LEft click etc..
Falcon_ASUS
ZT-c07932e9
@ZT-c07932e9
Have you tried reinstalling the touch version driver?
[Notebook] Troubleshooting - How to fix the Touchpad abnormal problems | Official Support | ASUS Glo...
