SHIFT+END and SHIFT+HOME not working in Zenbook S UX393
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-17-2021
05:37 PM
- last edited on
01-16-2024
01:29 AM
by
ZenBot
System: Windows 11 Home Single Language (21H2)
Battery or AC: both
Model: Zenbook S UX393 (11th Gen Intel)
Frequency of occurrence: allways
Reset OS:
Screenshot or video:
Detailed description:When I press Shift + End or Shift + Home in all Windows machine it selects the line till the End or beginning of the line. But it is not in my ASUS laptop
I press Fn key together with Right Arrow to access End
Battery or AC: both
Reset OS:
10 REPLIES 10
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-18-2021 11:20 PM
No.. I am using windows 11.
Let's localize this problem, I'm sure it's not an issue on Win 11 OS, because I tried the same key combination on Lenovo Flex 5 it works fine.Both (Asus & Lenovo) use OS Win 11 which I just installed.
Please test the key combination on the Zenbook S UX393 which is by your side. (or any series of asus's laptop).
Tell me whether the key combination works on your test?
Best Regards,
Best Regards,
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-19-2021 06:36 PM
Computer: Asus ZenBook Pro Duo 15 OLED UX582LR
OS: Windows 11 Pro 21H2 22000.258
My key combinations for the arrow keys work exactly as expected.
I tested using Microsoft Visual Studio 2019 and Microsoft Word 365.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-19-2021 07:34 PM
Hi there,
Let me check more about it.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-19-2021 11:20 PM
Hello ekop,
we have tried on UX393, UX561... and other model, but on Win10.
Both Shift +End or Shift+ Home are working. It would select the line that the pointer is pointing at.
Can you double check if you press FN+ESC, does the FN lock LED lights up or turn off?
And does other FN key or key combination work?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-21-2021 01:32 AM
After enabled & disabled the function key Feature (using Fn+Esc) , the probelm is solved.
Thank You
Thank You
