Setting external monitor as primary shifts Zenbook Duo ScreenPad+ above main display, cannot change
Steve123
System: Zenbook Duo
Battery or AC: Both
Model: UX481FLY
Frequency of occurrence: Every time
Reset OS: Brand new unit
Screenshot or video: Below
Detailed description: I have a dual monitor set-up. If I try to position either of the external monitors (top left or right) as my primary display, Windows shifts the ScreenPad+ above the main laptop display (see screenshot). I have tried every possible configuration and this cannot be changed.
External monitors are plugged in via a USB 3.0 Plugable dock, HDMI and DVI.
What is going on? This is unacceptable considering my workflow.
8 REPLIES 8
Blake_ASUS
Community Legend II
Hello Steve123,
Does this happen if you connect only 1 external monitor (total 3 monitor)?
And which project mode is it when the issue happen? Extend or Duplicate?
Steve123
Yes, it happens only with 1, doesn't matter which monitor
I extend all my monitors, never use duplicate.
Steve123
Come on Asus. This is not cool!
Blake_ASUS
Community Legend II
Hello Steve123,
If you put monitor 2 back to "below monitor 1"?
and can I have the complete monitor setting screenshot? or a video would be helpful.
I myself tried many time, but did not have similar issue.
