ScreenXpert 3 Wallpaper keeps on changing
romeoisla
I accidentally clicked set as ScreenPad Plus Background instead of Open on my friend's iPhone. Now, my wallpaper changes to my friend's photo on the ScreenPadPlus wallpaper every: 1)Windows Startup, 2) connecting to an external display, 3) disconnecting from an external display, 4) changing the display settings.
Some solutions I tried (but none worked): 1) Repair ScreenXpert, 2) Reset ScreenXpert, 3) Reinstall ScreenXpert. 4) connect to my iPad and set another ScreenPad Plus background.
Did anyone encounter the same problem? Thank you.
Model: UX482EA, OS: Windows 11
5 REPLIES 5
Falcon_ASUS
romeoisla
@romeoisla
Please refer to the following FAQ for troubleshooting.
[Notebook] ScreenPad Plus with ScreenXpert 3 - Introduction | Official Support | ASUS GlobalSorry for any inconvenience it may be caused.
romeoisla
Falcon_ASUS
https://zentalk.asus.com/en/discussion/61099/screenxpert-3-wallpaper-keeps-on-changing
@romeoisla
https://www.asus.com/support/FAQ/1047765/#C15
The wallpaper problem was fixed when I uninstalled the ScreenXpert software. However, if I install and run it again, the wallpaper reverted back (as seen in the screenshot).
Falcon_ASUS
romeoisla
https://zentalk.asus.com/en/discussion/comment/214822#Comment_214822
@romeoisla
Please double check if the ScreenXpert is completely removed. After removing, please go to the installation path and delete the entire ScreenXpert folder, then reinstall ScreenXpert again. Sorry for any inconvenience it may be caused.
romeoisla
Falcon_ASUS
https://zentalk.asus.com/en/discussion/comment/215008#Comment_215008
@romeoisla
Yeah, that helps. Thank you!
