My worry about the temperature of Zenbook duo 14 pro (2022)
FongPoui
Rising Star II
System: Windows 11 Home Single Language version 22H2
Battery or AC: Both
Model: UX8402ZE
Frequency of occurrence: 3-4 times (today)
Reset OS:
Screenshot or video:
Detailed description:Frankly speaking, I am quite worried about the tempeture of this model as I left my Lenovo brand for Asus because I like the duo screen system. Today, it occured 3 or 4 times as I left my zenbook for a while (installing some softwares, UE 5 project packaging, or even just leaving for a cup of coffee...), I found that my zenbook had gone to sleep and I could not awake it by any key. I did a hard reset (keep pressing on the power button for at least 30-40 seconds) before I got back to work.
That's why I have tried to get more information about the temperature status of this model: what is the average temperature for its normal status (at starting, after turning on other apps, etc.).
Today, when it had gone to sleep (or self power off) and hard to awake, I would like to be more informed about the temperature.
FongPoui
Rising Star II
It just occured again: ten minutes ago, I left my laptop for about 10 minutes and I got back, it was in screen off mode. I set it to sleep after 1 hour both in battery and charging mode.
I didn't turn on the screenpad but I remarked that the screenpad got warmer than the main screen! I was really surprised about that.
Falcon_ASUS
FongPoui
@FongPoui
If you restart the laptop, does the problem occur again?
If you think the laptop is overheating,  I would suggest you bring back your laptop to our repair center.
http://www.asus.com/support/Service-Center-All-Countries/
Also you can contact the local service center for help. The following is the contact information:
http://www.asus.com/support/CallUs#
ASUS_Bot
Rising Star II
