Issue with the fan
JorgeA
System: Windows 11.
Battery or AC:
Model: ASUS ZenBook 15 UX534FTC
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:
  MyAsus 3.1.0.034FTC
Since a few days after checking the status of the laptop on MyAsus there says: There may be an issue with the fan.
CPU  Temp = 50º (normal)
10 REPLIES 10
Falcon_ASUS
JorgeA
  1. System: Windows 11.
  2. Battery or AC:
  3. Model: ASUS ZenBook 15 UX534FTC
  4. Frequency of occurrence:
  5. Reset OS:
  6. Screenshot or video:
  MyAsus 3.1.0.034FTC
Issue with the fan
@JorgeA
If you reboot the laptop, does the problem still exist?
JorgeA
Yes. However, when the PC warms up enough the fans work.
I am convinced that the problem is in MyAsus
Falcon_ASUS
JorgeA
@JorgeA
If you remove and reinstall MyASUS, will the fan still get an error message?
JorgeA
Yes, I already did this procedure. When the error is detected by MyAsus it appears that the fan on the left side does not work. However, when a high performance computer is forced the ventilation works perfectly. By the way, MyAsus does not always give an error.
