inquiry for zenbook 14" oled laptop from 2024 regarding expansion of internal memory to 2tb?
DjSiko
I don't know how to get the correct information, so I'm writing to you here, I'm interested in your laptops from the zenbook 14" oled 2024 series, on your page it says that the maximum capacity that can be purchased is 1tb of internal memory, what I'm interested in is whether these laptops can upgrade to 2tb internal memory?
Falcon_ASUS
@DjSiko
Could you please provide the full model of your laptop?
Please refer to the following FAQ to find and provide the complete model of your laptop so that I can check the specifications.
[Windows 11/10] How to check the model name and BIOS version
DjSiko
@DjSiko
According to the webpage you provided, the product model is UX3405MA.
The maximum supported SSD specification for this model is 1TB.
If you wish to install a larger SSD, we cannot guarantee its stability and compatibility.
