Help with system fan replacement
Unicus
HI everyone,
I need help, I am from Canada and I need to buy a fan for my Zenbook Model Q304U.  The fan is dying. I blew it out, full of dust worked for an hour and then started making horrible sounds.  The drive is a SSD.  So it the fan, any advice on what type of fan I have to buy from Amazon.ca?
See attached photo and this close up of the part number on the fan
https://app.screencast.com/sUwZTjScCXpgm
Asus support was no help, they wanted me to send it in for repair.  I can't afford that.
14 REPLIES 14
Well, the official recommendation is to change the paste when you broke the connection between the heatsink and the processor.
On the other hand it will be okay for a while, but it won't extend the system lifetime for sure.
Thank you !
Does anyone here know how to replace just the fan, (number 1) Number 2 is the CPU heat-sink that will NOT come off the fan.  I watched some YouTube videos, all the fans come of easy, but mine is on rock hard tight.  See
My computers heatsink is attached to the fan, I can not remove it.  I seen YT videos and they take the fan off, but I can't.  See:
https://app.screencast.com/0t5sUjwxtDMPD
ZenBot
Community Manager
Community Manager
