HDMI to Display Port on LG ultrawide monitor
System: MS Windows 10 Pro 64-bit 10.0.19043
Battery or AC: AC
Model: UX581GV308
Frequency of occurrence: all the time
Reset OS:
Screenshot or video:
Detailed description:I can use my HDMI to DHMI no issues. However, I would like to use the higher refresh rate through the display port so I purchased an HDMI to Displayport cable and it does not work. The monitor also has a USB-C port and that also does not work. Can I not use these with this Zenbook?
Thanks
Blake_ASUS
Community Legend II
Hi there,
Can you specify the monitor model?
Or share the tech spec of it with us.
The monitor is this:
LG 34WP65G-B 34-Inch 21:9 UltraWide Full HD (2560 x 1080) IPS Display with VESA DisplayHDR 400 and AMD FreeSync
75hz
Blake_ASUS
Community Legend II
Hi there,
The Type C port of UX581 is supporting Thunderbolt 3 signal.
And the maximum output is 3840*2160,60Hz.
So you would like to get 75Hz with the Type C port?
How many Hz did you see when you connect the device and monitor by Type C to Type C?
