Grey lines and green flicker on webcam when using AC power
Quarter
System: Windows 10
Battery or AC: AC
Description: Grey lines and green flicker on webcam when using AC power
Model: UX533FD
Frequency of Occurrence: Always
Reset OS: No
Last edited by Quarter on 2019/12/9 09:37 As described above, the webcam image has grey lines and occasional green flickers. This only occurs when AC power is plugged in, everything works perfectly when using battery. I have removed and re-installed drivers with no success. This is a brand new laptop that I removed from the box yesterday. I see that there are two other questions with the same issue, but no answer has been provided. Is this a hardware issue and do I need to return my laptop or is there a software fix?
294 REPLIES 294
szbtamas1
Hello Blake,
Same issue with my laptop, doesn't matter if I'm plugged in or not.
Can you please help?
ASUS VivoBook S430FN
Thank you in advance!
Blake_ASUS
Community Legend II
szbtamas1
Hello Blake,
Hello @szbtamas1 ,
Issue happened both on Battery and AC mode?!
May I have a short video of the issue on your device?
szbtamas1
Hi Blake,
Yes same issue on battery and AC mode. Sometimes the flickering lines are white, sometimes grey.
Video is attached!
Thank you!
szbtamas1
Hi Blake,
I updated the BIOS and everything seems OK now!
Thank you very much for the support!
Blake_ASUS
https://zentalk.asus.com/en/discussion/comment/108406#Comment_108406
Hello @szbtamas1 ,
Hello Blake can you please tell me how to fix the problem, I have the same issue as well. I have the Zenbook 13 UX331FA-AS51
