Grey lines and green flicker on webcam when using AC power
Quarter
System: Windows 10
Battery or AC: AC
Description: Grey lines and green flicker on webcam when using AC power
Model: UX533FD
Frequency of Occurrence: Always
Reset OS: No
Last edited by Quarter on 2019/12/9 09:37 As described above, the webcam image has grey lines and occasional green flickers. This only occurs when AC power is plugged in, everything works perfectly when using battery. I have removed and re-installed drivers with no success. This is a brand new laptop that I removed from the box yesterday. I see that there are two other questions with the same issue, but no answer has been provided. Is this a hardware issue and do I need to return my laptop or is there a software fix?
294 REPLIES 294
Blake_ASUS
Community Legend II
alogarta
Hello @Blake_ASUS I am having a similar issue with the webcam flickering. The laptop is brand new. Asus ExpertBook P5440FA. Current BIOS Version is 311. Please assist. Thanks.
Hi @alogarta,
BIOS 311 is the one we released to fix this issue.
Please provide a short video of the current issue on your device.
alogarta
Blake_ASUS
https://zentalk.asus.com/en/discussion/comment/95211#Comment_95211
Hi @alogarta,
@Blake_ASUS Can I PM you the short video?
pmpena1
Hi @Blake_ASUS,
I am experiencing the same problem with my newly bought Asus Vivobook S15. Tomorrow is the last day for the 7 days replacement option of the seller. Should I return the unit or are there any solutions available for the issue?
Thanks.
ZT-08466863
Exactly the same issues brand new Zenbook UX581G purchased in may. Also main screen flicker.
ZT-08466863
digital907
Hi, got a brand new Asus ZenBook pro UX581G - after BIOS update, driver update, windows update, still the same problem with the camera (gray lines + green flickers) - camera flickers happend more often with AC connected. I have also noticed the main screen backlight flickers from time to time - Went in Intel UHD Graphics Control Panel - Power Settings - disabled all options - main screen back-light flickers gone. Flickers were subtle, but very annoying and hard on my eyes. (No, flickers had nothing to do with resolution, backlight setting or screen frequency).
I can take some quirks, but that camera is driving me nuts as I am using it for 2-3 hours daily. Any solution on the horizon @Blake_ASUS ?
Like this
