Grey lines and green flicker on webcam when using AC power
Quarter
System: Windows 10
Battery or AC: AC
Description: Grey lines and green flicker on webcam when using AC power
Model: UX533FD
Frequency of Occurrence: Always
Reset OS: No
Last edited by Quarter on 2019/12/9 09:37 As described above, the webcam image has grey lines and occasional green flickers. This only occurs when AC power is plugged in, everything works perfectly when using battery. I have removed and re-installed drivers with no success. This is a brand new laptop that I removed from the box yesterday. I see that there are two other questions with the same issue, but no answer has been provided. Is this a hardware issue and do I need to return my laptop or is there a software fix?
294 REPLIES 294
Wimindra
Hi, I have the same exact problem with everyone else here, mine is ASUS Vivobook S14 (how do i get my model number? this is my office asset)
Blake_ASUS
Community Legend II
Hello @Wimindra ,
Please kindly provide SN in the PM I send you.
How to find product Serial Number
ZT-08466863
Anyone struggling to update the bios needs to use an old memory stick. Newer ones formatted with high capacity, and that's practically all of them these days) don't work. Discovered after some head scratching - probably fat32 vs exFAT vs NTFS.
Mike
preswatt0
Hello @Blake_ASUS , I am having the same issue with my Asus Vivobook S512FL. I get grey horizontal lines and green flashes when I use the webcam. I have already attempted the most recent BIOS update from the product page, but the issue still persists. Can I provide the Serial number through PM to get a BIOS update?
neldahaby
@Blake_ASUS
I'm also having the gray lines/green flashing issue on 2 out of 2 ASUS ZenBook Pro Duos. Can you please PM me the link to the 311 BIOS?
