Fan problem, reported by MyAsus
FongPoui
Rising Star II
System: Windows 11
Battery or AC: AC
Model: UX8402ZE
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:I don't like at all this kind of problems. My Asus all checked up reported that there was a fan problem as shown in attached files. I disconnected all usb connections, uninstall and reinstall MyAsus App, but the problem persists. Very disappointed for a top laptop bought only a couple of months ago!!!
21 REPLIES 21
RAJU_MSC_MATHEM
Zen Master I
FongPoui
@Falcon_ASUS
Next step, should I reset to default (factory) in BIOS?
use different application which test FAN .
draco6769
same exact problem spent 2 hours on the phone with asus and factory reset the pc its a zenbook pro duo and its only 5 months old
both fan rpms are correct and when I uninstall my asus and reinstall it and run the test it comes back clear on the first run and ill get the fan fault after that unless i uninstall and reinstall again
i gamed all day on it with my asus on the second screen watching fan speeds and both run correctly
FongPoui
Rising Star II
@draco6769
If it is a bug for MyAsus app, it is very annoying and unpleasant one! When it concerns the fan, it is very serious...
Falcon_ASUS
FongPoui
@draco6769
@FongPoui
Have you tried removing MyASUS and reinstalling it?
[Notebook] How to install MyASUS application | Official Support | ASUS GlobalIf the problem still exists, please upload the following path file to the cloud storage.
C:\ProgramData\ASUS\ASUS System Control Interface\log
C:\Users\xxxxx\AppData\Local\Packages\B9ECED6F.ASUSPCAssistant_qmba6cd70vzyy\LocalState\log
I have sent you a message, please provide me with the link through the message.
FongPoui
Rising Star II
Just one minute ago, after restarting my zenbook, I rechecked the Fan by one-click-diagnosis, the result was ok. But when I rechecked the Fan by customer support, the result was bad: there may be a problem with the fan.
I will uninstall and reinstall MyAsus and recheck the fan...
