Fan noise
Matevok
System: Windows 11
Battery or AC: n/a
Model: Zenbook 14 UM3402Y
Frequency of occurrence: all the time
Reset OS: never
Screenshot or video:
Detailed description: After having my laptop for a while, it started producing a quiet coil whine, but after some time it started to really bother me. Today as i did a diagnostic in the MyAsus program i really got concerned when it got to the fan test. It revved up, but then it started to produce a vacum, or suction sound like when you block a vacums hose. I got scared and i quickly shut the test down. The suction stopped but the coil whine is still there. What should i do?
Falcon_ASUS
@Matevok
If your laptop fan is making unusual noises, it is recommended to send the laptop to the service center for cleaning or further inspection.
