Disappearance of Maximum lifespan option from Battery health modes
JavadRah
Hello
I recently bought a zenbook ux3402 Oled which was great, at first when I installed MyASUS in the Battery section there was a maximum lifespan mode option that kept the battery at 60% and refused to charge it more. Unfortunately, I don't know what happened that this option disappeared from my laptop.
Interestingly, this option is available on my friends' Asus laptops. It just disappeared from my laptop. Now my laptop is charging up to 80%. Meanwhile, I want my laptop charging limit to be 60%.
Can you think of a solution?
1 ACCEPTED SOLUTION
Accepted Solutions
@JavadRah
Yes, the current setting is at 80%.
Falcon_ASUS
@JavadRah
This is a design change in the MyASUS subsequent update, and it is considered a normal occurrence.
JavadRah
@Falcon_ASUS
Thank you for your reply
Do you mean that Asus has removed the ability to limit the charge up to 60%?
@JavadRah
