Connect to GPU using Thunderbolt 4
Nasit
System: Windows 10 64 bit
Battery or AC: Battery
Model: UX425EA (11th gen)
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:Can I connect desktop GPU to my Notebook using Thunderbolt 4?
Falcon_ASUS
Nasit
  1. System: Windows 10 64 bit
  2. Battery or AC: Battery
  3. Model: UX425EA (11th gen)
  4. Frequency of occurrence:
  5. Reset OS:
  6. Screenshot or video:
@Nasit
As far as I understand, the Thunderbolt box will have compatibility condition. You may first need to make sure that the Thunderbolt box is working properly. Thank you.
Rachelgomez123
Steps are given below-
Turn off your PC.
Remove the side panel.
Push your graphics card into the top PCIe slot.
Remove the backplates.
Screw your graphics card into place.
Connect your power supply.
Regards,
Rachel Gomez
ASUS_Bot
Rising Star II
