Camera LEDs keep flashing
cbraden1885
System: Windows 10
Battery or AC: AC
Model: q526fa
Frequency of occurrence: 3 or 4 times a week
Reset OS: yes
Screenshot or video: N/A
Detailed description: In my asus zenbook q526fa my camera LEDs keep flashing. I reset the camera, it stops then a few days later it will happen again. Laptop has bee rebooted more than once.
Error Code: CameraReservedByAnotherApp 0xA00F4243
No other application is open.
RAJU_MSC_MATHEM
Zen Master I
cbraden1885
  1. System: Windows 10
  2. Battery or AC: AC
  3. Model: q526fa
  4. Frequency of occurrence: 3 or 4 times a week
  5. Reset OS: yes
  6. Screenshot or video: N/A
disable camera access from other applications, except camera app from m.s store
Blake_ASUS
Community Legend II
Hello cbraden,
Sorry I'm a bit confused about camera LED flashing, do you mean the camera seems to be on when no app is using it?
Was there any new APP or driver installed before the issue start to happen?
Please enter Safe mode to see if there is similar issue.
