Battery Draining Fast on ZenBook 14 UM425QA
System: windows 11
Battery or AC: Battery
Model: ZenBook 14 UM425QA
Frequency of occurrence:
Reset OS: No
Screenshot or video: No
Detailed description: I purchased the laptop on 20 October for my coding and academic purposes. It has been 4 days. But I haven't got a good amount of battery life. it was mentioned that battery backup will get up to 16 hrs. Minimal usage last 5-6 hours which is not acceptable.
How will I get the best backup as a new laptop? Should I bring it to a service center?
Falcon_ASUS
muntaseer_jaheen
  1. System: windows 11
  2. Battery or AC: Battery
  3. Model: ZenBook 14 UM425QA
  4. Frequency of occurrence:
  5. Reset OS: No
  6. Screenshot or video: No
@muntaseer_jaheen
Regarding the use of batteries, please refer to the following.
[Notebook] Troubleshooting - How to fix the short battery life problem | Official Support | ASUS Glo...Please also refer to the following remarks.
Zenbook 14 UM425 (QA)|Laptops For Home|ASUS Global2. Battery tests conducted by ASUS on December 18, 2020 using the 1080p Video Playback (local) scenario. Test configuration: ZenBook UM425QA, FHD panel 250 nits, AMD R5-5600H, 512 GB SSD, 8 GB RAM. Test settings: WiFi enabled but disconnected (not connected to any access point), Windows Power Plan set to Balanced, display brightness set to 150 cd/m2, NumberPad off. Actual battery life may vary depending on product configuration, usage, operational conditions and power management settings. Battery life will decrease over the lifetime of the battery.
ASUS_Bot
Rising Star II
