Audio not working on Asus Zenbook 14 earphone jack
pietyrebel
The external audio jack on my Asus Zenbook 14 has stopped working after windows 11 update. Bought a new jack. Updated drivers. still does not work. Audio only plays on laptop speakers
The earphones and jack work on other laptops
Falcon_ASUS
pietyrebel
@pietyrebel
According to what you described, I would suggest you bring back your laptop to our repair center to check the audio jack.
http://www.asus.com/support/Service-Center-All-Countries/
Also you can contact the local service center for help. The following is the contact information:
http://www.asus.com/support/CallUs#
antoniosgrift
Enable and reinstall the driver in the Device Manager
Type and search [Device Manager] in the Windows search bar, then click [Open]. Check the arrow next to [Audio inputs and outputs], then right-click [your speaker device] and select [Enable device]
Greetings,
Peter
ASUS_Bot
Rising Star II
