Asus ZenBook Pro Duo 15.6 - freeze NEED diagloses (+ Additional asking for Opinions )
shield2142
System : Window 11 Home
Battery or AC : When it connected to AC. ( Dosen't have much time with Using battery )
Model : UX582ZM-H2043W
Frequency of occurrence : 1~3 Times Per Week
Reset OS : Done (Once), And I Just bought it.
Screenshot or video : https://youtu.be/dW4nHVgHZu4
Detailed description:It sometimes completely freeze so that forcing me to long push power button (Even ctrl+shift+Esc dosen't work). And it occurs not even when I play game, but also when I browse File Explorer.
So What I am wondering --> Is [RTX 3060 for laptop] not enough for running 4K Display in stable way?
6 REPLIES 6
Falcon_ASUS
shield2142
  1. System : Window 11 Home
  2. Battery or AC : When it connected to AC. ( Dosen't have much time with Using battery )
  3. Model : UX582ZM-H2043W
  4. Frequency of occurrence : 1~3 Times Per Week
  5. Reset OS : Done (Once), And I Just bought it.
  6. Screenshot or video : https://youtu.be/dW4nHVgHZu4
@shield2142
What is the BIOS version and system version you are currently using?
[Notebook] How to check the model name and BIOS version | Official Support | ASUS GlobalWhich version of Windows operating system am I running? - Microsoft SupportDoes the problem only happen when connected to the external monitor?
Or does it happen in all usage situations?
Since the video seems to be unplayable, could you please confirm again?
shield2142
Falcon_ASUS
https://zentalk.asus.com/en/discussion/66083/asus-zenbook-pro-duo-15-6-freeze-need-diagloses-additio...
@shield2142
https://www.asus.com/support/FAQ/1030673/
https://support.microsoft.com/en-us/windows/which-version-of-windows-operating-system-am-i-running-6...
▶ What is the BIOS version and system version you are currently using?
[ Microsoft Window 11 Home 64bit 10,0,,22621 ]
FirmWare Information:
Release date = 20220516
Version = UX582ZM.302
System Type = 64bit operating system, x64 processor
Window Specification :
OS bulid = 22621.819
Experience = Windows Feature Experience Pack 1000.22636.1000.0
▶ Does the problem only happen when connected to the external monitor?
No, I have ever connected to any External Monitors. It Only occurs when using Main Monitor & Screen Pad Plus.
And It seems to happend in all usage situation maybe.
There are some "usage" when The [Freezing Problem] Occured.
1) Playing Lost Ark (MMORPG) at Main screen, and watching Youtube on ScreenPad Plus.
2) "Google Chrome + File Explorer + Window Command Console" on Main display, and nothing on screen pad plus.
3) Youtube Chrome (ScreenPad Plus) --> Add PUBG online (Main display) --> Add GeForce Experience Overlay_alt+z (Main Display) --> GOT FROZEN
▶ Since the video seems to be unplayable, could you please confirm again?
I just uploaded video(4K) this morning, so it might be on process when you try to watch. It will be avaliable soon.
Turbonetics
Can you open MyAsus to monitor what is the temperature of your laptop when problem appear?
Falcon_ASUS
shield2142
https://zentalk.asus.com/en/discussion/comment/237580#Comment_237580
@shield2142
I have forwarded the information to the relevant department. We will keep you updated and your consideration will be very much appreciated.
