System: Windows 11
Battery or AC: both
Model: Asus Zenbook Pro 16X OLED ux7602zm
Frequency of occurrence: always
Reset OS: yes
Screenshot or video:
Detailed description:
I want to connect external monitor LG Gram View 16
but it doesn't work.
LG's manual says:
"This product is designed to be used only with a laptop. The device to be connected with the monitor must support DisplayPort Alternate Mode (DP Alt Mode) and power output (USB PD) at 7.5 W (5 V / 1.5 A) or higher. "
The Asus manual says:
Thunderbolt™ 4/Power Delivery combo port
The Thunderbolt™ 4 port is compatible with USB Type-C®
standards, and provides a transfer rate of up to 40 Gbit/s for
Thunderbolt™ 4 devices. Connect your Notebook PC to a
DisplayPort, VGA, DVI, or HDMI external display and experience
high-resolution display features via Intel® Thunderbolt™
technology. Connect a power source rated 20V/5A to charge the
battery pack and supply power to your Notebook PC.
