Asus TUF Dash 2022 - Thunderbolt 4 issues - Not charging through T4 cable
Mark4024
System: Asus TUF Dash2022
Battery or AC: AC
Model: FX517ZR
Frequency of occurrence: New laptop so always
Reset OS: No
Screenshot or video:
Detailed description:New laptop with updated drivers. I'm unable to install thunderbolt driver due to error in photo attached. Connected to Caldigit TS4 dock, ethernet works through Thunderbolt cable but not charging.
Falcon_ASUS
Mark4024
  1. System: Asus TUF Dash2022
  2. Battery or AC: AC
  3. Model: FX517ZR
  4. Frequency of occurrence: New laptop so always
  5. Reset OS: No
  6. Screenshot or video:
@Mark4024
I would recommend that you try to restore the system to check if the problem improves.
[Windows 11/10] How to reset the PC and remove all of my personal files, apps and settings | Officia...If the problem persists, since your laptop was newly purchased, I would suggest you report to the dealer to confirm whether it can be returned or exchanged.
ASUS_Bot
Rising Star II
