Wi-Fi 6 Not Connected
cedubal
System: Win 11
Battery or AC: AC&Battery
Model: Vivobook Pro 14X
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:
my computer is vivobook pro 14x and it has mediatekxxx wlancard. This wlancard supports wifi-6. My modem also supports Wifi-6. But when I connect to this modem with my laptop, I see that it is wifi-5, not wifi-6. When I connect to the same modem as my mobile phone; I see the Wifi-6 icon on my phone. Any suggestions?
8 REPLIES 8
Falcon_ASUS
cedubal
https://zentalk.asus.com/en/discussion/comment/221991#Comment_221991
yep:) my router supports wifi-6. pls check Tp Link AX 1500
AX1500 Wi-Fi 6 Router
  • Wi-Fi 6 Technology: Archer AX1500 comes equipped with the latest wireless technology, Wi-Fi 6, for faster speeds, greater capacity and reduced network congestion.
  • Next-Gen 1.5 Gbps Speeds: Archer AX1500 dual-band router reaches even faster speeds up to 1.5 Gbps (1201 Mbps on 5 GHz band and 300 Mbps on 2.4 GHz band)*
  • Connect More Devices: Wi-Fi 6 technology communicates more data to more devices using revolutionary OFDMA and MU-MIMO
@cedubal
May I know the result of removing the wireless network card driver and reinstalling it?
Or, if you connect your laptop with other APs that support Wi-Fi 6, will the situation be the same?
cedubal
Falcon_ASUS
https://zentalk.asus.com/en/discussion/comment/222040#Comment_222040
@cedubal
Yess 🙂 very very thank you for helping. That's it
willjoe2442
If your Microsoft Windows PC has a wireless network adapter, but it is unable to detect your router's WiFi network or does not connect reliably, you might have an older wireless network adapter, or its drivers might be out of date.
Regards,
Will
ASUS_Bot
Rising Star II
