Replacement for wifi card
Ammaar
Hello, I own a Asus TUF F15(FX506HCB) laptop which has a mediatek wifi 6 MT7921as it was having some issue
i wanted to replace it with another wifi card , can someone tell me a suitable one for that model?
Falcon_ASUS
@Ammaar
According to what you described, I would suggest you bring back your laptop to our service center for further confirmation.
