6GHz Wi-Fi SSID not showing up
kcafe703
Laptop: ASUS TUF Gaming F17 (2022) (FX707ZM)
CPU: i7-12700H
Wireless LAN Card: Intel BE200
OS: Windows 11 23H2 (22631)
Intel Wi-Fi driver version: 23.30.0.6 (2024.01.21)
_______________________________________________________
The AX201 wireless LAN card in my FX707ZM failed and I replaced it with a BE200.
I uninstalled all AX201 drivers and installed the latest drivers.
I ran a 6GHz hotspot on my Galaxy Tab S9 to make sure the 6GHz on the BE200 was working fine, but I don't see any 6GHz wifi on the laptop.
I am using the latest version of Windows 11 (23H2) and have drivers installed with version 22.70.0 or higher. Also, South Korea allows 6GHz.
I'm wondering why 6GHz is not showing up on my FX707ZM.
Screenshot_20240314_161815_Settings.png스크린샷 2024-03-14 161849.png스크린샷 2024-03-14 163651.png
Falcon_ASUS
@kcafe703
As the wireless network card was installed by you after purchase and not provided by us, we cannot guarantee its stability and compatibility. We suggest you first confirm if the network card can successfully detect 2.4GHz or 5GHz signals, or try swapping the network card into another computer for testing to ensure its functionality. Sorry for any inconvenience it may be caused.
