01-08-2021 04:43 AM
01-09-2021 10:23 PM
tin.bedenkotake your laptop to nearest Asus service center, ask technician to check fan.
- System: Win 10
- Battery or AC: Both
- Model: N705FD
- Frequency of occurrence: Almost every time
- Reset OS: Five times in last two years
- Screenshot or video:
Detailed description:
For some reason GPU fan is not working every time. To be fair - it works two out of ten times. If I restart my pc - it will not work after that. The only way to get it back is to power it off and wait couple of hours...
The problem is THE SAME AS WITH TUF!!! Same as here:
https://zentalk.asus.com/en/discussion/38789/tuf-gaming-fx505gt-laptop-not-performing-well/p8
Asus replaced my fan, I've tried disabling every little thing software wise - the problem still persists. I've disabled every Asus Service - the problem still persists. I've disabled fast startup in windows - the problem still persists...
It is like that since the beginning. My warranty is running out in two weeks and the problem is still not solved. What to do?!
VivoBook Pro 17 N705FD GPU Fan NOT WORKING
01-11-2021 05:17 AM
01-11-2021 05:23 AM
01-11-2021 05:40 AM
tin.bedenkoyou fixed the problem by yourself and learnt how to troubleshoot.I've partially fixed my problem by disabling sleep mode and fast startup. That way, my GPU fan will work if I cold boot the machine (meaning the first start on that day). If I restart - it definitely wont work anymore. Then it is either fresh OS install, if I need it in a hurry, or wait a couple of hours (probably for some register to clean/reset itself since I cannot remove the battery to make a "soft reset" by draining the power from it).
All in all - I'm 90% sure that there is some BIOS problem that went unnoticed till now.
