Unsolved problem (Notebook display)
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
09-15-2020 02:50 AM
Hello guys,
I would like to ask your suggestion in relation to my notebook problem.
I bought Asus Vivobook A409FJ in Q4 2019.
However, there is an issue where the display flickers at unpredictable moment without any clear reason.
When the display flickers, the notebook immediately can work any more. So, I have to make a hard reboot and the notebook is back to normal.
However, it happens so often and disturb my job.
Then, I went to Asus service center for the first time. They only reinstalled the OS, but it didn’t solve the problem.
Then, I went to Asus service center for the second time. They replace motherboard with the new one, but it still don’t solve the problem.
Unfortunately, the problem is even getting worse. In addition to flickering, the display now can suddenly turn into blank and the notebook hangs. It have happened many times since I took it from the service center for the second time.
Some say there must be a conflict causing this problem. Is it highly possible? I only install common programs.
I also have checked the latest version of the drivers.
T is truly embarrassing if I have to go to service center many times.
So, what is going on with my notebook? Is there anyone experiencing the same problem?
Or, is is Asus Vivobook A409FJ has a special problem that needs special treatment?
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-15-2020 06:19 PM
Hello Sammy,
Please provide your SN in the PM I send you.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-17-2020 03:09 AM
RAJU.MSC.MATHEMATICSAnyway, I don't have any expertise in coding or programming.https://zentalk.asus.com/en/discussion/comment/113389#Comment_113389
good. now check with ubantu live 64bit os.
I am worried that I would potentially put my notebook at risk if I surf further into the system, BIOS, etc.
Anyway, thanks for your solution.
- « Previous
- 1
- 2
- Next »
