The bluetooth stero sound reversed on VivoBook S14 Oled
System: Windows
Battery or AC: Both
Model: S3402ZA
Frequency of occurrence: always
Reset OS: yes
Screenshot or video:
Detailed description:The left sound comes from right and right comes from left and this is only happening on bluetooth connection. Same device on wired connection works fine and laptop speaker. Please update from bios or driver update please
Falcon_ASUS
durgeshkashyap925
  1. System: Windows
  2. Battery or AC: Both
  3. Model: S3402ZA
  4. Frequency of occurrence: always
  5. Reset OS: yes
  6. Screenshot or video:
@durgeshkashyap925
What are the BIOS version, system version and Bluetooth driver version you are currently using?
Also, which model of bluetooth headset are you using?
ASUS_Bot
Rising Star II
