Qualcomm AR956x wireless network adapter hidden in device manager
josecomiajr
System: Windows 10
Battery or AC: Battery
Model: ASUS X541SC
Frequency of occurrence: Daily since last week
Reset OS: No
Screenshot or video: Yes
Detailed description:
I can't connect to WIFI due to this problem. I tried restarting the computer several times, sometimes it connects for a few minutes then disconnects again. I also tried to uninstall driver, restarted computer, clicked "Scan for Hardware Changes" in Device Manager but still the problem persists. I also tried to Update Driver but computer prompts that driver is up to date. Can connect via LAN cable but LAN option is not available all the time.
RAJU_MSC_MATHEM
Zen Master I
josecomiajr
  1. System: Windows 10
  2. Battery or AC: Battery
  3. Model: ASUS X541SC
  4. Frequency of occurrence: Daily since last week
  5. Reset OS: No
  6. Screenshot or video: Yes
in my laptop same wifi Device is embedded .. Currently driver v 10.0.3.462 is installed and running without problems without hidden mode.
which driver version you have installed.
Blake_ASUS
Community Legend II
Hello josecomiajr,
May I have the screenshot of the error message?
