Problem in asus vivobook
Mayank_
Yesterday because of me maybe some files are deletd or replaced after that when I tried to restart it was showing blue screen with error unstoppable boot system when I move curser it again came back to same screen i don't know what to do it's under warranty only a month happened from purchase
Falcon_ASUS
@Mayank_
According to what you described, I would recommend you to back up your data first and then restore the system.
[Windows 11/10] How to reset the PC and remove all of my personal files, apps and settings
