My vivobook (r551ln) is unable to start with power indicator light turns on and off after 2 sec.
ZB1
My Vivobook (r551ln) is unable to start with power indicator light turns on and off after 2 sec.  I can't even enter BIOS, after  Embedded Controller (EC) reset/hard reset  and even after disconnecting and reconnecting CMOS battery.  Anyone can help advising what's happened and how to fix it ?  Thank you very much.
Falcon_ASUS
@ZB1
According to what you described, I would suggest you bring back your laptop to our service center for further confirmation.
