Indicator light
Eric8924
My battery indicator light is not  turning on when i shutdown my laptop and started charging
Usually its always working
Any solution?
Im using vivobook
Falcon_ASUS
@Eric8924
May I ask for the complete model number of the laptop you are using?
How to find Model Name
Are you referring to pressing the shutdown option in the system settings, then connecting the charger while the laptop is powered off, and the charging indicator light does not come on?
If you turn on the laptop and then connect the charger, does the charging indicator light come on?
Im using asus vivobook go 15 e1504f
Yeah the indicator light is working well when i turned on the laptop while charging
But when i shutdown and charging the laptop, it does not work
Usually the indicator light , always working well, when i shutdown while charging.
@Eric8924
Please check the power management settings on your laptop to see if there are any options related to indicator lights during charging or when the laptop is shut down. If the problem persists,  I would suggest you bring back your laptop to our service center for further confirmation.
