how to reduce hardware reserved memory
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
04-05-2020
09:25 AM
- last edited on
01-16-2024
01:28 AM
by
ZenBot
System: Windows 8
Battery or AC: AC
Description: 1.1GB is hardware reserved
Model: asus vivobook f570
Frequency of Occurrence: Always
Reset OS: No
hi, i have a ASUS Vivobook F570zd laptop. in task manager it shows that only 6.9 GB is usable and 1.1 GB is hardware reserved memory which seems unusual because my friend has only 90mb as hardware reserved memory. i have tried all the below methods yet no change: -- msconfig -- paging file -- advanced system setting OS Name Microsoft Windows 10 Home Single Language Version 10.0.18362 Build 18362 System Manufacturer ASUSTeK COMPUTER INC. System Model VivoBook_ASUSLaptop X570ZD_F570ZD System Type x64-based PC System SKU Processor AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx, 2000 Mhz, 4 Core(s), 8 Logical Processor(s) BIOS Version/Date American Megatrends Inc. X570ZD.310, 04-07-2019 SMBIOS Version 3.1 Embedded Controller Version 255.255 BIOS Mode UEFI BaseBoard Manufacturer ASUSTeK COMPUTER INC. BaseBoard Product X570ZD BaseBoard Version 1.0 Platform Role Mobile Secure Boot State On PCR7 Configuration Elevation Required to View Windows Directory C:\WINDOWS System Directory C:\WINDOWS\system32 Boot Device \Device\HarddiskVolume 1 Installed Physical Memory (RAM) 8.00 GB Total Physical Memory 6.95 GB Available Physical Memory 3.21 GB Total Virtual Memory 18.9 GB Available Virtual Memory 13.2 GB Page File Space 12.0 GB Page File C:\pagefile.sys Kernel DMA Protection Off Virtualization-based security Not enabled Device Encryption Support Elevation Required to View Hyper-V - VM Monitor Mode Extensions Yes Hyper-V - Second Level Address Translation Extensions Yes Hyper-V - Virtualization Enabled in Firmware Yes Hyper-V - Data Execution Protection Yes dgpu; gtx 1050 vram: 4gb igpu: AMD radeon vega 8 (1gb) pls help me to resolve this because the 6.65 GB ram is really pushing me back in gaming .
Battery or AC: AC
Reset OS: No
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-06-2020 10:44 PM
Is your friend using same laptop model ? are you sure ?
disable secureboot and then Disable all hyper V features in windows features options.
enable secureboot
enable Virtualization-based security .
processor have 8 cores , so HRM might be increased.
enable secureboot
