Grey lines and green flicker on webcam Grey - please help!
mhaber7
System: Win10
Battery or AC: both
Model: X412FJ
Frequency of occurrence: all the time
Reset OS:
Screenshot or video: yes
Detailed description:Detailed description:My camera is green and grey flickering all the time!! even when not plaguued to AC. it happense with any app. i have upadted all the drivers. BIOS is updated to version 302 (attached). what is the solution??
14 REPLIES 14
mhaber7
these are the images of the BIOS and the problem
Blake_ASUS
Community Legend II
Hello mhaber7,
For your issue, it's more likely to be the environment interference and light issue.
If you move to another room, does it happen as well?
mhaber7
thank you, yes, it happense in any light and everywhere.
Blake_ASUS
Community Legend II
Hello mhaber7,
Please kindly send your device to service center for further examination.
