Cannot disable/shutoff Screenpad & use External Monitor on HDMI
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-20-2020
12:42 PM
- last edited on
01-16-2024
01:40 AM
by
ZenBot
System: Windows 10
Battery or AC: AC
Description: Cannot disable/shutoff Screenpad & use External Monitor on HDMI
Model: VivoBook S15
Frequency of Occurrence: Always
Reset OS: No
I just got a new laptop. I'm learning to work with it. I use an external monitor via HDMI. When the Screenpad is enabled it works as if I have 3 monitors, so I have to move an external mouse over the screen pad to my external. It works but is not smooth. I want to have the Screenpad in regular touch pad mode. But when I do this, the mouse no longer works on my external monitor. I also tried to shutoff the Touchpad completely. It too does not work. How do I "disable" the Screenpad and still have the mouse/touchpad work with my external monitor?
Battery or AC: AC
Model: VivoBook S15
Reset OS: No
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-20-2020 07:19 PM
Hello suzriv99,
Sorry I'm a bit confused.
I try to test this situation myself.
I am able to control the pointer by touchpad on the external monitor
both under temporary touchpad mode( screepad mode) and regular touchpad mode.
May you record a video of your usage?
Also, may I have a screenshot of your Display Setting> Display?
