Battery auto drain
A1N23K
I just bought Asus Vivobook S15 OLED laptop recently. I noticed that my battery is auto draining while in shut down state. I charged the laptop to 79% and then i shut down it but when i opened it next day the battery was 67%😢. Why is that, please help
Falcon_ASUS
@A1N23K
May I inquire whether your BIOS and system versions have been updated to the latest versions?
If you've used MyASUS to check the battery, have any errors appeared?
[Notebook] MyASUS - System Diagnosis
My BIOS and Windows are Updated to latest Version. I have also checked battery on MyASUS app, there's no issue shown there.
@A1N23K
According to what you described, I would recommend sending your laptop for repair to confirm whether there is an abnormal electrical leakage from components on the motherboard.
