09-16-2019 10:48 AM
09-19-2019 05:29 AM
RAJU2529 posted on 2019/9/19 17:07 Frist try to check with new Battery in service center. if that is work then you must replace batte ...Okay, I'm out of warranty so I might need to get a new battery for the same. Thanks for the help again!
09-19-2019 05:41 AM
kunal_lakhwani1 posted on 2019/9/19 17:59 Okay, I'm out of warranty so I might need to get a new battery for the same. Thanks for the help ...without finding the problem , dont buy battery . first go to service center , they tries to use used battery
