no flashlight when using OTG in low battery
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-15-2020 04:17 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-28-2020 11:26 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-28-2020 11:28 AM
dhenz.isipIm also having this problem i have tencent version and its annoying when playing. How to fix this.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-08-2020 11:43 AM
it keep shows up while battery below 15%
and the bottom charger port also not working.
I've been using this phone for 3 months.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-19-2020 02:33 AM
Shubhangkar
adams.toomerI'm getting the same thing and I can't use the bottom port to charge. You find a fix?
lung-butterSame exact problem here. WTF, brand new ROG phone 2.
arif.malufihttps://zentalk.asus.com/en/discussion/comment/46417#Comment_46417
@Anders_ASUS its always like this when the battery low , twice / second i think
devraj.ja
It's always showing " No flashlight when using OTG in low battery" automatically comes when battery is less than 15%. I can't use bottom part of display as well drop down menu. Please let me know how to resolve.
Park83https://zentalk.asus.com/en/discussion/comment/69655#Comment_69655
Hi, I am having the same issue. As of writing my phone is at 50% so I cannot replicate the issue. But when battery is ~15% the phone will persistently show this error. It is as if the phone thinks it is connected via OTG and that the flashlight is on (as the error says) when it is not on both counts. And that this 'false OTG' connection keeps on disconnecting and reconnecting. This makes swiping down the notification tray difficult. In USB mode menu, I think, you can see that the phone is reconnecting and disconnecting.
I have raised this issue with tech support and they recommend a factory reset but that is not an acceptable solution for me.
yoga.agustinaCan you please check if the OTG function (connecting external HDD) works when the battery is above 15%? Thanks!I have the same problem as well.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-23-2020 07:11 PM
