01-19-2020 06:52 AM
01-19-2020 11:15 AM
01-19-2020 12:11 PM
gonzaaa.92Yea that's kinda my point it is supposed to work in the selected period but it never does , it works outside the selected period ! Also the battery care function is on .Well, the turth is that the battery will get fast charged up to 80% and then the charging speed will be drastically decreased for the remaining time so that the battery gets fully charged by the final time of the period.
The battery care function must be turned on in order for it to take effect but it will only get activated in between the selected period. You will know when the function is running if you see the icon of a battery inside an oval at the upper left corner of the screen.
01-20-2020 06:08 AM
