High temperature / CPU usage / battery drain on 2009.47
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
09-23-2020 04:27 PM
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
As many posted on the forum. I and everyone have similar issue. (This is already upgraded for whole night and a full charge)
CPU also peak at 2.84/2.96 as from Armoury Crate even didn't do anything
Temperature goes high
Battery drain quickly
"Android System" also taking all battery usage from Battery page
What I observed:
From running processes, "Google Play Service" always show up, which not the case in old firmware
What I've tried to fix:
Wipe data (all data not just cache) for Google Play service and Armoury Crate. After cleaned, seems the CPU back to 826Hz, but after I restart the device, it go back to 2.84/2.96 all the time
There may be something wrong on this?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-25-2020 05:17 PM
ronald1985"System updated" when search updates (with 2007.27) and zip removed from site.https://zentalk.asus.com/en/discussion/comment/118286#Comment_118286
What do you mean?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-25-2020 10:27 PM
23% battery consumption? WT...?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-26-2020 12:04 AM
After several time finding to temporary fix the problem while waiting next update,
I try to disable google play store and restart the phone...it seems like CPU back to normal.
After doing some experimental i found that CPU will high and started heat and drain the battery after installing/updating apps.
So for the temporary iam using this method each time after update/installing apps
Install/update apps>disable play store>restart phone.
Iam keep searching if i found any method to resolve the problem. My ROG 2 under monitoring
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-26-2020 02:05 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-26-2020 02:49 AM
jasonwchBattery and cpu with temperature control for your device asus rog phone 2Please tell us some basic information before asking for help:
- Model Name:
- Firmware Version:
- Rooted or not:
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
- CPU also peak at 2.84/2.96 as from Armoury Crate even didn't do anything
- Temperature goes high
- Battery drain quickly
- "Android System" also taking all battery usage from Battery page
What I observed:
- From running processes, "Google Play Service" always show up, which not the case in old firmware
- Wipe data (all data not just cache) for Google Play service and Armoury Crate. After cleaned, seems the CPU back to 826Hz, but after I restart the device, it go back to 2.84/2.96 all the time
