04-13-2025 04:47 PM
I've just bought rog phone 9 since 1 week and it happened 3-4 times the phone starts overheating till 42-43 degrees even in idle state, with fast battery drain. Others users have noticed it's an issue since the last update.
I manage to solve it by manually cleaning phone's ram usage from settings, and temperature drops to ~30 degrees in few minutes. It's clearly caused by some background process that the phone should be able to detect and close immediately before the overheating occurs, so I just let the devs know to fix this in future updates
04-16-2025 04:00 AM
Hello @MrBlackCrush
What you are experiencing is normally caused by the optimization process after an update, in where the phone gets to optimize apps and usage according to your own usage. After a week it should start working normally.
04-16-2025 05:46 AM
I hope so because when the problem is not there, this phone has the best passive heat dissipation I've seen
05-10-2025 12:07 PM
Habe das auch einmal bemerkt das es im Ruhezustand plötzlich sehr warm wird, so ziemlich mittig an der rückseite. Kann gut sein das sich wärme ableitet. Nachdem ich das Phone ausgeschalten habe ist es immer halb 30 sec. Abgekühlt also wieder kalt. Habe immer die Bildschirmhelligkeit ca. Auf der hälfte.
Kannst du das mit dem Ram mehr erklären. Wo kann man das manuell löschen?
05-10-2025 01:33 PM
Go in settings > advance settings > mobile management and clean ram
Anyway the problem is very less frequent now, but when it happens I still have to do this manually, or phone won't cool down
