10-23-2019 11:05 PM
12-21-2019 11:10 AM
12-22-2019 12:24 AM
bunnyfastardAm waiting for your feedback after u test it again , bcuz if its hardware issue then i can also get replaced mine motherboard too.https://zentalk.asus.com/en/discussion/comment/33518#Comment_33518
ASUS Service center confirmed that its a hardware issue and its with the faulty motherboard. My motherboard is being replaced and that should hopefully solve the issue as they say.
Should be receiving my phone in a couple of days. Shall keep you posted about the issue once i receive the phone.
Thank you for your help and recommendations
12-22-2019 01:25 AM
SwarajHii,https://zentalk.asus.com/en/discussion/comment/34454#Comment_34454
Same issue here 😞
12-22-2019 01:50 AM
bunnyfastardTy i will do the same nowhttps://zentalk.asus.com/en/discussion/comment/35608#Comment_35608
Hii,
They replaced my motherboard and it is working flawlessly now. Go to the service center and they will do it for you.
It is actually a manufacturing defect.
12-22-2019 09:22 AM
nayyar.rahul18how about this issue? i dont have problem with my back panel. the only problem im facing is my left trigger flickers. can anyone tell us how to solve this?@developers/Mods
The right air trigger has serious issues. I tried using them in PUBG for 4-5 hours continuously. The left AT worked like a charm while the right air trigger could never fire consistently for even 3 seconds. I have done all the nifty tricks like factory resetting/resetting/all possible change in settings in armory crate and pubg settings.
Can i do anything else now?
