ROG phone 7 power button issue.
manuvipin
My phone's power button malfunctions frequently. Most of the time it takes multiple button presses to turn off/on the screen or lock the screen. Power button menu doesn't come up sometimes after the long press. Double tap on home screen function works well for locking and unlocking. Noticed this started happenning after a software update( I guess).
Tried switching on and off the shortcuts and SOS, almost all settings related to power button have been tried.
Anyone with ideas to solve this issue? Thanks in advance.
10 REPLIES 10
roguedroid
Rising Star I
Which version you are at right now?
Have you tried formatting system after it all?
Haven't tried factory reset yet. Was hoping to get some solution before trying that.
SnowFuhrer
The power button quit on mine completely.  On mine it acts like it's on permanently since the phone cannot be powered off unless I disconnect the battery internally. I once dropped the phone after this happened and it worked intermittently for a bit so I think it's a hardware issue in my case, not sure if it's the same problem here.
I'm not sure either if it's hardware or software. Have dropped my phone quite a few times as well.
