❌Final call for collecting logs regarding overheating & other bugs on android 14❌Please co_operate
Sam1991
Rising Star II
As an Asus ROG 7 user I kindly ask you to send your logs to @Mattias_ASUS if you haven't already so we could get rid of the overheating issue and other bugs in the next upcoming update.
I am also disappointed and angry like you but with spreading F words we can't get anywhere.
We all want something in common and that's a smooth OS. please co-operate with me and send your logs until we all figure out a way to downgrade. Thanks for your understanding.
Follow these steps to send your log to " The moderators @Mattias_ASUS ". Thanks in advance.
The steps to create the log are here:
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
@iswaraKITT @llfranco17ll @Disappointed_us @ric3 @CleverRuby @toganstuff
If you happen to know any other ROG 7 users experiencing from high overheating and other bugs please let them know about this thread so they can also follow these steps and send their logs.
17 REPLIES 17
Dude, if u r a developer find us a way to downgrade to android 13 and save us all. !
downgrade is not hard
u just have 2 problem with downgrade
1. do you have the file needed for the downgrade ? if you dont have the file, even if you r a developer, u can't do the downgrade
2. are you brave enough to do the downgrade ? in some case when the downgrade fail, ur phone will turn into a brick
toganstuff
Rising Star II
Matias already has my log from the calculator app
Disappointed_us
Rising Star II
I have send the log second time already, hope it's fixing problem this time
iswaraKITT
sorry I didn't reply, but I've sent my logs to matthias
