04-18-2024 03:58 AM
As an Asus ROG 7 user I kindly ask you to send your logs to @Mattias_ASUS if you haven't already so we could get rid of the overheating issue and other bugs in the next upcoming update.
I am also disappointed and angry like you but with spreading F words we can't get anywhere.
We all want something in common and that's a smooth OS. please co-operate with me and send your logs until we all figure out a way to downgrade. Thanks for your understanding.
Follow these steps to send your log to " The moderators @Mattias_ASUS ". Thanks in advance.
The steps to create the log are here:
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
@iswaraKITT @llfranco17ll @Disappointed_us @ric3 @CleverRuby @toganstuff
If you happen to know any other ROG 7 users experiencing from high overheating and other bugs please let them know about this thread so they can also follow these steps and send their logs.
a month ago
Same here. Who knows that might cause us another issue that wasn't there in the first place.
a month ago
they should send it right away, at least gradually repair it and not wait for one big god, it's been at least 3 months, and as far as I know personally, a cauldron of people left Kuki during that time and more and more are leaving
a month ago
Yeah man I totally agree.
