Rog Phone 6 pro display is hot and battery drain
GEBESHEFF
Hi all,
My phone suddenly start to burn even when im using it for even for facebook. The battery starts to drain fast. Last week my phone loses signal and after a factory reset, the card is fixed. But suddenly soon after that, the phone starts overheating. Is this from the last update? or bad battery?
8 REPLIES 8
Mattias_ASUS
Hello @GEBESHEFF
Which update are you on? Normally the phone does get hot a bit after a reset as it works updating all the apps and working in the background, are you still experiencing this?
Hi Mattias,
Yes, I understand the after reset situation. But its been like 2 weeks now. Im on the latest software update . Attaching screenshot. The display become very hot after a few minutes of facebook browsing, or chat in the messenger.
I wonder if you could maybe create a log while recreating the heating issue so that the devs can look into it, when you are done please feel free to send me a PM with the link.
I'm writing the steps down below.
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
Hi again Mattias,
I just done what you've asked. Im sending you the link for the log file:
https://drive.google.com/file/d/1uyiHFn9r3DywIuG0ZlnQ6E0-dzLtZV59/view?usp=drivesdk
And for the screen recording video:
https://drive.google.com/file/d/1uz-DDFlN4PNaDn7oIRqNgOvn7joYWOk_/view?usp=drivesdk
After finishing the Log, the phone temperature rises more. But i hope you will see what is wrong from this one. Im looking forward hearing from you and hope that you will find the problem.
Kindest regards
Ivayo Gebeshev
