Battery drain after update
Athen03
Hi moderator, can you please fix this battery drain issues after update on 34.0210.0210.276 version.
My Rog 6 battery draining so fast after this update. Even not in use. Please i need solution asap. Thank you
4 REPLIES 4
Athen03
No reply yet?
My phone was heating all the time. I have been charged my battery almost 4 times today.. even not opening anything its getting heated. Please developer do something about new updates. I dont wanna make my battery condition worse
same thing happened to me too, even reading epub draining my battery so much, and overheating issues when playing games, usually i got 36°C when playing CODM, but now, i got 44°C.
try using 60 or 90 fps ingame and low or medium settings and check your room Temperatur and turn the screen darker and only use x-mode  in-games and look if some apps are open in the background that can cause the battry and cpu work to much an can overheat because of that
